PAC 1218's with a F13????
Old Feb 10, 2010 | 04:38 PM
S13LSx's Avatar
Default PAC 1218's with a F13????
are they enough spring or would you go with something else?? 1518?
Old Feb 10, 2010 | 09:35 PM
S13LSx's Avatar
230/232 and .595/.585 on a 112 LSA
are the 1218's enough or would you go 1518's?
Will also be swapping in a set of 243's off a c6 vette. Would like to know how much I can shave off to raise the compression a little when I clean them up and install the valve springs at the machine shop. I was thinking .005-.010??? The 243's have 64.45cc chamders stock and I would like to take them down to a little over 60cc.
might need a 114 lsa to clear???
Old Feb 10, 2010 | 10:39 PM
01ssreda4's Avatar
1218s will work fine, as well as 1518s would be even better, however I would check installed heigth.
Old Feb 10, 2010 | 11:47 PM
LTX355's Avatar
it has probably been done many times but i would chose option 2 to b on the safe side plus 1518s will live way longer because they will always b further away from coil bind...
Old Feb 11, 2010 | 06:31 AM
S13LSx's Avatar
Thanks for the info. I'm going 1518's for durability then.
I found this on performancetrucks.net
So you want to figure out how much to mill:
It takes about .005" milling of the block deck to remove 1cc of volume. It takes .007" milling to remove 1cc from an LS1 head
Simple Milling Math:
You have a stock 66cc chamber and you want to get down to 63cc
66-63 = 3. You have to remove 3cc's
.007 x 3 = .021. So to get your 66cc chambers down to 63cc you'd have to mill ~.021.
You can also do the reverse, say you want to mill a head .030 to figure out how many CC's that removes you take .030 / .007 = ~ 4.28. Milling a stock 5.7 head .030 puts your chamber at ~ 62.
I guess I will try and take about .015-.018 off and try to get the heads right at 62cc chambers. That should put it very close to 11.0-1 with long tubes, ls6 intake, stock 243's, and a F13 cam with PAC 1518's. Should make a nice street driver with 3.73's and a 26" tire at the track. BTW it's a M6 car.
Old Feb 16, 2010 | 01:23 PM
KennethS's Avatar
1218 = 1518
1518's are just nitrided and polished..among other things
They're rated .650 because the nitriding allows for higher stresses (on a spring, highest stresses are on the surface).
Old Feb 16, 2010 | 02:02 PM
SOMbitch's Avatar
Even though they may be rated to .650 I would run a double because the lobes are so aggressive.....
