Mysterious part in motor oil
hi there
i'm new on this forum, so first a little introduction: my name's Fabian, i'm from Switzerland and i own a 1998 chevy Camaro Z28
after changing the motor oil, the motor mechanic discovered this broken part:
(the 10 cent euro piece has the size of about 3/4 inch)
has anybody an idea what this part could be?
it's metal and magnetic
the engine works fine so far...
Thanks!
Thanks!
hi there
Thanks!
Thanks!
how urgent is a replacement?
when do this bearing retainers brake? too often too high rpm?
Considering the age of your car, I wouldn't be suprised at some breakage. I would recommend this upgrade to prevent it from ever happening again...
http://www.thunderracing.com/catalog...&sid=901#P7566
This will replace the shafts, bearings, and keepers with new improved parts which will not come apart.
Thanks,
Shane
Thanks,
Shane
Wow. Just wow. All it would take is one for me to pull them all off and replace. Those lil things could do alot of damage.
I agree, I wouldnt drive it anymore. Since your overseas it may be easier to find the problem rocker or rockers and replace them immediatly. I would have the Comp Cams trunion upgrade, in link above, ordered and on its way as soon as possible.
You need a press to push out the old trunions and press in the new ones. If you dont have a press Spectacle Solutions will do the press work for you. I think they charge $80 for the service. I cant remember if you can just buy them outright or if they are on an exchange basis.
I know I plan to have my truinions upgraded very soon!!!
