what's a good solvent for the valve train & heads just what the title says... i'm looking for a solvent i can soak them in cause my valves are just that dirty. i've managed to get my heads mostly clean but there are some parts that aren't easy to get to the carbon build up just won't budge. would sea-foam be good? should i just buy new valves? |
wire wheel on a bench grinder for the valves. just dont go up the stem any where the stem rides inside the guide. |
heads off the motor? valves and springs still in the head? position the head so the intake or exhaust ports face up. fill the ports with brake cleaner ,and let it sit for a couple days. use a new firm toothbrush to scrub the valve and bowl. |
heads are off and springs and valves are off as well. i've been using break cleaner on them all day with a scotch brite pad and they still look crappy. |
let them soak in a bucket of solvent for week ,see if that works. |
my question is what would be a good solvent to let them (heads and valves) sit in? |
Originally Posted by bww3588
(Post 13194514)
let me know when you can blue. is your dad's solvent safe for the heads and the valves? |
Originally Posted by phdraperinc
(Post 13194893)
You could try a carb dip bucket too for the vavle and springs, drop them in and let them sit over night |
| All times are GMT -5. The time now is 06:02 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
