New head/cam ?'s
New head/cam ?'s
So I just bought a head cam pkg from TSP, AFR 205's, MS3, ported oil pump, double roller chain. I know the AFR heads only come with springs rated for .600 lift and the MS3 is .603/.609.
Which springs should I be looking to buy? Should I also be looking at aftermarket lifters? I've read a few posts about spinning the ms3 to higher rpms, how much higher past the stock rev-limit would be optimal? What would be required to spin to higher rpms? Thanks in advance for replies.
