Do i have everything i need for the cam swap?
Alright do i have everything i need? Engine has 94K on it. Do i need new lifters too?
TSP camshaft
Standard PRC Platinum Spring Kit
Hardened Chromoly Pushrods
Basic Heads & Camshaft Bolt & Gasket Kit
GM LS2 Timing Chain
TSP Ported LS6 Oil Pump
Anything else? Im ready to order, oh ya and HPE is doing the install not myself.
TSP camshaft
GM LS2 Timing Chain
Its right at 95000 now....if it would be good insurance i would have no problem doing the lifters as the ls7s arent that expensive...
Think it will add much to the install?
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well, you said cam swap. Why are you taking the heads off? If you are gonna do that much atleast get a compression mill on your heads as well as replace the lifters. I wouldn't go to the trouble to replace your stock lifters unless you are planning on running a ridiculous cam.
no very lightly driven, i only go WOT about once every 2 weeks, itll be a DD under the curve cam, something like the Torquer V2, but im gonna talk to tsp to see what they recommend
no i dont plan on pulling the heads at all at the moment. I thought i would need that gasket kit because it said camshaft and head gasket kit. i guess i dont need that after all eh? that would be nice
TSP camshaft
GM LS2 Timing Chain
TSP camshaft
GM LS2 Timing Chain
