LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   Comp Cams trunion upgrade Q's??? (https://ls1tech.com/forums/generation-iii-internal-engine/1289825-comp-cams-trunion-upgrade-qs.html)
Maroslut2001 Jun 4, 2010 10:41 PM
I just got my upgrade kit in the mail and have started getting all the old stuff out of the rockers... My question is how far do i press the new bearings in? enough so that the snap rings keep the center from moving? Flush with the rocker? or in a little ways to keep the center tight?
Maroslut2001 Jun 5, 2010 11:57 AM
BUMP????? Anyone have an answer please???
baker163 Jun 5, 2010 01:24 PM
rocker arm upgrade
press the bearing's flush to the edge of the rocker but not so far in that it's tight on the trunion,also make sure the lettering on the bearings are facing out.
RARON455 Jun 5, 2010 01:52 PM
YUP, press the bearings in against the edge of the rocker, and if you dont have the right spacers they recommend then take the shaft and put a snap ring on it, press it in against the bearing and then flip it over and put the other ring on it, and you are done,, also like stated above,, make sure the numbers on the bearings are facing out.
Maroslut2001 Jun 5, 2010 02:23 PM
Cool thanks guys!!! and i made sure the lettering is facing to the outside... so its normal to have a little play in them then?
baker163 Jun 5, 2010 04:25 PM
Yes a little play is normal.
Maroslut2001 Jun 5, 2010 04:45 PM
Cool thanks for your guys help... Motor is almost all put back together, hopefully getting it back in the car this weekend then all thats left is the clutch, flywheel and adj mc!!! Cross your fingers for me that my first engine rebuild will work out good lol
© 2026 MH Sub I, LLC dba Internet Brands
