What do you check/used Ls1 engine
Old 06-05-2010, 02:56 PM
fast poncho's Avatar
Default What do you check/used Ls1 engine
Can anybody tell me what to look for when buying a used Ls1 that has been sitting for a couple of years out of the car.I'm interested in buying one but i want to make sure all that time sitting around did not affect anything inside the engine.Is there anything i can do to check it or is there anything i should be worried about.Any feedback would be greatly appreciated.
Old 06-05-2010, 03:15 PM
HotSilverBird's Avatar
I would pull the plugs and look for rust. Turn the engine over by hand with the plugs out. With the plugs out it should turn smooth and easy. Drain the oil and look whats in it. Pull the valve covers and look around.
Old 06-05-2010, 03:35 PM
That sounds good any body else have experience with this.
Old 06-05-2010, 09:44 PM
89 formula350's Avatar
i like to see the pan off check for metal or a cleaned eng.. but thats me... pulling the plugs is fine but rusted walls will still turn free... so unless u pull the heads too its his word.
Old 06-06-2010, 01:27 AM
izzman55's Avatar
look at the crank, take the pan off and turn it over. also check block itself for cracks or anything suspisous, i just bought one two days ago.
Old 06-06-2010, 02:57 AM
joecar's Avatar
What is your intention...?
