Polluter cam? Good for hwy hammerin?
Old 08-22-2010, 02:05 AM
stunna p's Avatar
Default Polluter cam? Good for hwy hammerin?
my next step is a cam, just got my moser 9 from brute speed.
so heads are too much chee$e right now. balla on a budget my wife tells me..
anyway, my goal is to be a hwy king/street car. (no strip.)
Is the polluter gunna be better because its proven vs a custom grind.
I want to be the sickest street worthy/streetable i can be. i think im just afraid of leaving any hp's on the table.
some helpful input would be cool.
thanks stunna
Old 08-22-2010, 08:26 AM
BaddBird's Avatar
Get a cam spec'd for your set up. I would think the polluter would be more of a strip cam than a street cam.
Old 08-22-2010, 08:46 AM
BJSS25's Avatar
Well technically the polluter is a custom grind, lol. I have the polluter and it is a awesome street cam. I went from a ms3 to the polluter and would never go back. You will make great power down low, middle, and up top. My car was built more for the street and i love it. Hope this helps.
Old 08-22-2010, 07:20 PM
RJB01camaross's Avatar
What kind of numbers did your combo make? Also what heads do you have?
Old 08-22-2010, 07:24 PM
BJSS25's Avatar
430hp and i have TSP CNC ported ls6 heads with LS6 intake.
Old 08-22-2010, 08:16 PM
180ls1's Avatar
what gears do you have?
Old 08-23-2010, 12:57 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I would have to disagree with the part where you said:
Nothing against the polluter, but in the end, that may not be what you are looking for.
I think a custom grind tailored for what YOU will be doing is the better proven method. That is why you hear of people with a custom 224/227 cam waxing someone with a 240's duration. Bigger is not alway better. Only when refering to Texas.
Yes, a big cam is pretty easy to get away with if you are a from-roller.
Old 08-23-2010, 01:40 AM
180ls1's Avatar
also you need to consider what lobes to use and how much top end maintenance you will want.
Old 08-23-2010, 04:42 PM
BJSS25's Avatar
I have 3:73's. I have never been beat by a smaller cammed car.
Old 08-23-2010, 09:27 PM
stunna p's Avatar
i think with some good roller rockers, i think i can brake into the 420's +
hp area with a cam only set up..... i just want the power band to be violent..
i mean, like at 4500 rpm. floor it and it just gets off.... not like a truck cam, that just excellerates and pulls the same at all rpms like the stock cam.
i want the violent excell above 4500 rpm....thoughts
Old 08-23-2010, 09:35 PM
BJSS25's Avatar
You want be disappointed, since your close to Mooresville why don' t you stop by Tick Performance and talk with Jonathan. He can give you all the info you need to help you decide.
Old 08-23-2010, 11:17 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Reconsider the roller style rockers and just roll with the 135$ trunion upgrade and rock the stockers. You again, will not be disappointed with that selection.
Old 08-24-2010, 08:59 AM
ScrapinBye's Avatar
Whats better about the Polluter than the MS3? I'm just curious because i have the MS3 and I have mixed feelings about it. I kinda think lower-to-midrange power is lacking with my cam, but up top it's ridiculous.
Old 08-24-2010, 09:19 AM
BaddBird's Avatar
I bet if the truth be known several big cam guys feel the same way.
Old 08-24-2010, 12:15 PM
stunna p's Avatar
ive got 4.11 gears, a big cam like the polluter will still be fine low to mid rpm? cruising, hwy, not just racing etc. right? its not gunna make my car unroad worthy is it....
im just after that violent 4500rpm+ pull....
Old 08-24-2010, 06:31 PM
BJSS25's Avatar
The polluter was designed to provide low to mid power and tons on the top end. You will feel a difference.
As far as 4500rpm pull, are you doing this to street race or what? And yes it will pull like damn train past 4500rpm.
Old 08-24-2010, 06:47 PM
WKMCD's Avatar
Save for heads and get the right cam for them. Great average power is where it's at. With heads you can use a smaller cam, make the same or more peak HP and much more mid range power.
I'm a huge fan of big heads/small cam setups.
Just my $.02
Old 08-24-2010, 07:02 PM
fatmat80's Avatar
you can still get a polluter and then get heads down the road..Im sure someone out there has a polluter under a set of tfs or afrs out there..good luck with your build op..
Old 08-24-2010, 10:29 PM
stunna p's Avatar
when u say feel the difference? like it gets a giant evil kick in the *** at
4500 or so and up....... and yes street/hwy race.. im just worried about getting a cam that leaves hp's on the table. i want violent.violent!
i want the hit to be savage and scary....
Old 08-24-2010, 10:32 PM
Zmg00camaross's Avatar
go crazy and get a TREX cam. its violent like you want it.
Quick Reply: Polluter cam? Good for hwy hammerin?
