What is your ide oil pressure for Cam Only LS1s
Old 08-23-2010, 02:13 AM
00cls1camaross's Avatar
Default What is your ide oil pressure for Cam Only LS1s
I am cam only and have a ported TSP oil pump.
When i am idling and fully warmed I am a smidgen above 20 and sometime it will flicker under 20 psi. Is this ok?
What is everyone elses like?
Old 08-23-2010, 05:55 AM
m1a2d3's Avatar
seems a little low is that at idle
Old 08-23-2010, 05:57 AM
m1a2d3's Avatar
didnt see the idling part what is the pressure at 3000 rpm
Old 08-23-2010, 06:39 AM
blsnelling's Avatar
My 5.3 is about 40 at idle, hot, 650 RPMs.
Old 08-23-2010, 06:54 AM
JaYZeig's Avatar
my ms4 t/a will idle about 40-45psi hot @ 800rpm..but thats a ported ls6 pump on mobile 1 5w30 if it mattters
Old 08-23-2010, 07:17 AM
Duffster's Avatar
cam only here, running about 60 psi (dash gauge) at idle...once the car warms up and I've been driving a while it mellows out around 45-50...
Old 08-23-2010, 07:24 AM
bjamick's Avatar
Mine stays at 60 at idle warm.
Old 08-23-2010, 07:27 AM
608kZ28's Avatar
at idle and all warmed up, im a little above 40 psi.
Old 08-24-2010, 12:01 AM
at 3000 rpms it is above 40 psi.
I have a ported TSP pump too. It is shimmed. What should I do?
I mean do you think it matters that it gets 120+ out here in the summer?
Old 08-24-2010, 01:06 AM
Atomic02's Avatar
cam only sitting a lil above 40 at 800rpm idle.
Old 08-24-2010, 01:37 AM
itsslow98's Avatar
Im at mid 40s warm idle of 950rpms with a melling high volume oil pump.
Old 08-24-2010, 03:10 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
As long as its goin up to around 40psi under a small load then I wouldnt worry. Now if drops under a load...yikes. I have seen both sides of the fence with the ported pumps. Mine is a ported LS6 pump and it idles at around 30ish.
Old 08-24-2010, 03:28 AM
SMALLBLOCKHERO's Avatar
mine idles at about 30, but jumps to 60 with just a touch of the throttle and stays there as im driving about. stock replacement pump on a 100k short block with new cam and valvetrain.
Old 08-24-2010, 08:25 AM
bamaballa205's Avatar
I sit around 20psi at idle using 5w30 Mobile One. Once I give it gas or start driving it's around 45-50 psi and that's on a ported LS6
Old 08-24-2010, 11:36 AM
How long have you been driving with oil pressure like this? Mine sounds exactly like yours does.
Old 08-24-2010, 12:11 PM
slt200mph's Avatar
On a factory guage mine is about 45 PSI..65 PSI while driving around...keep in mind that we are looking at info from a major POS guage/sending unit. If you really want to know what your oil pressure is try using a real guage instead of the factory crap on your dashboard...
Old 08-24-2010, 12:19 PM
$750 L98's Avatar
Mine runs 25-30 at hot idle ~450rpm, and about 45-50 at light load/cruise, WOT is around 60+
Old 08-24-2010, 12:27 PM
02_Z28_G's Avatar
Could changing the oil maybe help a little?
i live out in houston and friend of mine works at chevrolet so he changed the oil and put 5w30 in it and i was having oil pressure problems so i went ahead and did a change at my house and went with 10w40 and haven't had a problem since. i idle at around 40 warmed up
Old 08-24-2010, 12:36 PM
Squirts11's Avatar
Rule of thumb: for every 1k rpms, you want 10psi oil pressure.
When I was cam only w/ ported ls6 oil pump, I idled around 40psi, and hit 70 @ WOT.
Now, with cam/heads, etc, I idle around 45psi, and cruise around 55-60psi!
Old 08-24-2010, 12:49 PM
fatmat80's Avatar
on factory guage im at 60 while idleing hot, but with a touch of throttle im up to 75.im running a tsp ported pump as well..
