Do you guys submerge the stock rockers, pushrods, lifters in oil
I soaked my lifters for a good 36 hrs before install. never had a problem. Rockers were preowned and still a lil oily so i figured they would be alright and they have been
I submerge pushrods as well so they fill. Then when I install them I put my thumb over the hole on top so they don't drain. My oil to the rockers comes up quicker. Also, I use Redline Assembly Lube on the pushrod cup of the rocker and the valve stem contact with the rocker to cover those minutes where no oil is supplied from the lifter. It can be minutes too.
