6.0 Oil Pump Pickup question.....
Old 08-25-2010, 11:46 AM
Silvy6.0's Avatar
Exclamation 6.0 Oil Pump Pickup question.....
I am putting a 6.0 (LQ9) in my 99 Camaro. Of course I have to have the ls1 oil pan so I ordered the oil pan, and pickup from gmpartsdirect. Got everything in. I noticed when I was pulling off the pickup that the ls1 o-ring was a different color. I believe one was blue and the other was green. Like I just said "I believe". I can double check to verify. Which one do I need to put in there? I figured I use the new one that came with the new pickup. Not sure though.
Old 08-25-2010, 05:45 PM
Silvy6.0's Avatar
Anyone?
Old 08-25-2010, 06:05 PM
69LT1Bird's Avatar
GM Oil Pick-Up Tube O-Ring (1st Design)
12557752
BLUE SEAL
Specifics:
* Oil Pick-Up Tube O-Ring ea.
* Chevy/GMC Pick-Up (1999-2000 LS V8) 1st design
* F-Body (1998-2002)
* Cadillac CTS-V (2004-2007)
* Corvette (1997-2008)
* Thickness = 3.55mm (0.140")
ID = 23.60mm (0.930")
GM Oil Pick-Up Tube O-Ring (2nd Design)
12584922
RED SEAL
Specifics:
* Chevy/GMC Pick-Up (1999-2000 LS V8 engines with 2nd design pick-up tube)
* Trailblazer (2003-2008 With LS V8 engine)
* Hummer H2 (2003-2008)
* Hummer H3 (2008 With LS V8 engine)
* Chevy/GMC Pick-Up (2001-2008 LS V8 engines)
* W- Body (2006-2008 With LS V8 engine - Impala, Lacrosse, Grand Prix)
* Thickness = 4.20mm (0.165")
ID = 20.69mm (0.815")
Old 08-31-2010, 04:13 PM
Silvy6.0's Avatar
So I should use the red?
Old 08-31-2010, 04:19 PM
69LT1Bird's Avatar
You said that you have a F car pickup tube and pan, correct? If that is right, like I highlighted above, you need the Blue O-ring. The Red O-ring is for a pickup tube that has a recessed area for the O-ring to sit into.
Old 09-01-2010, 12:57 PM
Silvy6.0's Avatar
Yeah, I am using all of the FBody pickup and pan. I didn't know if the pumps were different.
Old 09-01-2010, 01:09 PM
69LT1Bird's Avatar
The O-ring is pickup tube specific
Old 04-30-2011, 10:09 PM
383mazda's Avatar
Time to bring this up again...
I also have a 6.0L going ina car that requires an F-Body oil pan. I think I have a 6.0L gasket set, it had three o-rings, green, black and red.
The red was too small, the green and black both fit the tube. The green was thicker than the black. I went with the black and it was a very snug fit. Should I take it back out and look for the "blue" o-ring before I put the motor in the car?
Old 05-01-2011, 06:44 AM
69LT1Bird's Avatar
Like I said earlier, they are pickup tube specific. If you got a 6.0L truck gasket kit, the O-rings are for their tubes. If you are using a F-car pan and F-car tube, spend the $5.00 and get the F-car O-ring, if anything, its for your piece of mind.
Old 05-01-2011, 09:49 PM
383mazda's Avatar
sounds good - I figured if the LS gen III oil pumps are the same - where the pick up tube sticks into them would be the same. I guess that would make too much sence for a GM engineer, lol. I'll grab the correct blue o-ring tomorrow. thanks!
Quick Reply: 6.0 Oil Pump Pickup question.....
