which heads used afr 205s or prc 2.5 ls6
Old 08-26-2010, 08:27 PM
bigfatls6's Avatar
Default which heads used afr 205s or prc 2.5 ls6
These are going on my 2001 z06 stock ls6 with 231/237 585/595 112 cam with fast 90/90 25% under drive pulley, Lg long tubes with x pipe and B&B prt exhaust. IM debating between holding out for a nice set of 62cc afr 205 heads or just buying a set or prc 2.5 ls6 heads. I have seen several sets of the afr heads sell for $1400-1700 on here in the past few months so the price is pretty close. Which head would work best with the cam I already have?
Old 08-26-2010, 10:07 PM
TXZ28LS1's Avatar
im sure everybody will say AFR as far as quality and performance. but its tough to beat the performance and price for those PRC heads.
Old 08-27-2010, 08:50 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Here's another idea to toss out at ya. We're running $200 off all PRC Aftermarket casting heads next week. That puts a set of PRC 215 or 227 heads at $2200. If you order them without springs you'd be under $2000 for a brand new fully cnc set of heads...
Just something to kick around!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 08-27-2010, 11:49 AM
Red99TA's Avatar
I'm sure that cam would work great with 205s (or the other heads mentioned). Pat G spec'd a cam specifically for my 62cc AFR 205s and it happens to be very close to your cam specs (mine's a 232/237 .61X"/.61X" on a 113+4 LSL lobes). I need to hit the dyno again now that I've got a ported 90/90 setup with more timing on there but I hope to hit around 460RWHP/410RWTQ.
Also unless you're very easy on it you're going to want a new clutch. My LS6 clutch was slipping within the first 1K miles of me going with the H/C/I and it only had 30K miles on it total.
Old 08-27-2010, 04:29 PM
chrs1313's Avatar
afr hands down...
Quick Reply: which heads used afr 205s or prc 2.5 ls6
