L92/98 heads & manifold on LS1
Nope, needs a minimum bore of 4.00" like the LS2, been covered many times before. The valves would hit the cylinder walls of an LS1.
If you're looking for cheap good heads, check out PRC. If you want some great heads, then get AFR 210s or Trickflows.
