Bolt Size for Yella Terra's?
Old Sep 5, 2010 | 07:04 PM
chopperloco's Avatar
Default Bolt Size for Yella Terra's?
Part #6624-didn't come with the bolts..anyone know the size?
Thanks
Dom
Old Sep 5, 2010 | 09:34 PM
vettenuts's Avatar
Use your stock bolts.
Old Sep 6, 2010 | 07:13 AM
Default Thanks...
...but i don't have them.
Old Sep 6, 2010 | 07:33 AM
vettenuts's Avatar
It may be easier to order a new GM set from a vendor that discounts them. I ended up with a longer length due to the required shims to correct the wipe pattern on mine and mine are now socket head cap screws and not a hex head like the stock bolts.
Old Sep 6, 2010 | 09:16 AM
quadman's Avatar
+1. when i was playing around with the rockers i found a GM set on ebay that was much cheaper than getting them from a dealer. the longer ones i used with the RHS heads/spacer/Yella Terras i got from McMaster Carr. they are socket head cap screws as vettenuts describes.
Old Sep 6, 2010 | 12:23 PM
...anyone remeber the lengths etc.?
Old Sep 6, 2010 | 07:27 PM
vettenuts's Avatar
Mine were M8 X 1.25 X 50mm (length) socket head cap screws but mine were also bought longer due to the shims I need under the rockers. If you have no shims or thinner shims my length may be too long.
Old Sep 9, 2010 | 07:27 AM
Thanks!
Dom
