LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   AFR's? (https://ls1tech.com/forums/generation-iii-internal-engine/1327970-afrs.html)
WS6SP33D Sep 8, 2010 08:17 PM
AFR's?
So i've ran afr heads on every mustang that i've had and now that i'm new to this motor can i expect the same results of satisfaction or should i go with a different head? Thanks guys
NVR_SPDS Sep 8, 2010 08:52 PM
You WONT be dissappointed with AFRs on an LS engine! Im really hoping to pick me up a set soon.
Also, Tony Mamo from AFR is a regular here, so if you got any questions, hes the man to talk to.
WS6SP33D Sep 8, 2010 09:02 PM
Cool thats what i wanted to hear beacause ive ran nothing but afrs thanks
The_Rizzle Sep 8, 2010 09:03 PM
That depends. The quality of satisfaction may be more so with an ls engine compared to a ford. :engarde:
Its actually hard to buy a "bad" aftermarket head for the gen III engines. They're all good. AFRs have their usual amazing standard, TFS heads are very good, and even the Darts are awesome with a little work.
Arc00TA Sep 8, 2010 09:25 PM
AFR is a great choice, and the only brand that has a smog legal head IIRC (the 205's). Like they said, Tony Mamo is in here all the time answering questions so thats a good bonus.
WS6SP33D Sep 8, 2010 10:16 PM
Well i was looking at the TFS and looks like they are good heads also it will def be between those and AFR's
© 2026 MH Sub I, LLC dba Internet Brands
