which should i use? melling 10295 or 10296??
Hey guys decided to go with a melling pump from summit since ill get it next day and cheaper. Which is a better choice for me or really don't matter? The 10295 or 10296. Plan on adding intake and heads later. As of now its a 01 fbody with 228 cam 42lb injectors exhaust and gears. DD. Thanks everyone
This is going to go back and forth, because I've asked the same question you asked. It's whatever you want. A 295 will work with no problem for your setup, and so will a 296. I have a H/C/I, stock bottom end and am using a 296 with no problems. Great oil pressure! I used the green o-ring and used the spring that it came installed with. It's just going to be whichever one you want really.
