cam swap and now car starts and dies?
Old 10-08-2010, 05:55 PM
poltergeist 02's Avatar
Default cam swap and now car starts and dies?
just wondering if anybody has run into this before? it's an ls1 with a 228/230 cam, ported stock tb,slp lid, long tubes, ory, 3600 stall. the car has been dyno tuned. this only happens on a start after the car has sat for a few hours. if i start the car it will fire up and then die. if i start the car and give it a little throttle it will rev and then idle fine. i'm at a loss here. just hoping someone can help me out with some good input. thanks guys!
Old 10-08-2010, 06:18 PM
Darkman's Avatar
One possibility is a leaky fuel injector. If that were the case you would probably also be experiencing some dieseling at shut down.
Old 10-08-2010, 06:22 PM
KevinR's Avatar
My guess is that you may need to take it back to where you got it tuned and tell them to work on the cold start.
Old 10-08-2010, 07:01 PM
02sslayer's Avatar
my car does the same thing, but its kinda funny. if i have the heater or ac running when i start the car it will start idle a couple times then die.
Old 10-08-2010, 07:11 PM
i was thinking the same thing but the car only has 25k on the clock. could a injector go bad from sitting or from age?
Old 10-08-2010, 07:32 PM
LS1TECH Sponsor
1Hawk's Avatar
I could almost gaurantee you its the open loop tune...or cold start tune...I doubt its mechanical
Old 10-08-2010, 07:47 PM
DaddySS's Avatar
Thre's are a few sections of the tune specifically for starting - one of them is start up friction which gives the engine a few seconds of extra idle and then decays quickly - it sounds like you need to fine tune the start up tune.
Have a look here and you can see what I mean:
https://ls1tech.com/forums/pcm-diagn...er-tuning.html
Old 10-08-2010, 07:58 PM
Darkman's Avatar
The normal causes for a leaky injector include wear or accumulation of contaminants that prevent the internal pintle valve from closing. Contamination can include gasoline that has aged from sitting.
Old 10-09-2010, 08:14 AM
i was looking through this thread and it seems to help your idle if your idle isn't good at all. my situation is a little different. the car only won't idle on a startup after the car has sat for a while. after you let it run for 30 seconds or so you can shut it off and it will start back up just fine.
Old 10-09-2010, 09:13 AM
KevinR's Avatar
I very seriously doubt that it's an injector and that it's in the tune. Did it start having this problem right after you got the car tuned?
Old 10-09-2010, 10:15 AM
yes, it started happening right after the cam swap/tune. if i do the tps relearn will that mess up the tune at all? does this sound like something that actualy has a chance of helping my situation?
Old 10-09-2010, 04:43 PM
ok, i tried it and still the same. maybe it is in the tune.
Old 10-09-2010, 04:51 PM
blsnelling's Avatar
Highly unlikely it's anything but the tune.
Quick Reply: cam swap and now car starts and dies?
