Ok is there some kind of stock replacement rocker arms I can use that are affordable yet strong for hydraulic setup!
I think the OEM rockers (with the trunion upgrade for reliability) are about as "strong" as you can get without going to some pretty pricey stuff. Yella Terras are a good middle ground.
+ 1 on the stock ones,just do the trunion upgrade. There was a test done with pricey aftermarket rockers vs stock and the stockers were better. Use the search .
