Suggested Cam Specs for 425+ RWHP
Wow, thank you everyone for the influx of information. This is what I needed to help pinpoint what I should be looking for. I may reach out to Pat G, seen his name come up quite a few times while searching for cam info. I think I will end up going G5X1 as the specs for that seem to be right in line with what most were saying for specs. Thanks again everyone.
Rob
Rob
It's a huuuuuuge cam and they listed 435rwhp for a vette similar to his.
maybe maybe not, there are also well tuned cars with more duration and more aggressive lobes that dont make that power all else being the same.
I would just shoot for a cam that fits your criteria in terms of drivablity and how you want the power delievey and not worry about what the dyno says. In this case a 233/239 on 113 would work well i believe.
I have a custom BRE 224 cam with unported 243 heads that makes 444 rwhp. My setup makes 365 rwtq @ 3000 rpm and 400 rwtq @ 3800 rpm. It's not slapped together by any means but when you optimize a setup it's amazing how well it works. Click my sig link for more details.
A cam that makes that kind of power on stock heads will be on the larger side and will be a little sluggish in the low rpms. It really depends on your definition of "decent drivability" IMO pick up some ported heads and make a decent amount more power more efficiently and have more power under the curve
#32
#33
http://forums.corvetteforum.com/c5-g...-new-cams.html
I was looking at Texas Speed kits but EnglandGreen sales a COMPLETE kit including 1 tube of Red Locktite
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
(copy-paste from corvette forum)
Price is $1595 shipped to the lower 48 states.
Always remember, you WILL need a computer tune after a cam swap - so factor in some $$$ for that item.
Our cam package contains the following parts:
1 x EnglandGreen custom grind cam
1 x GM Front Cover Gasket
1 x GM Front Cover seal
2 x GM Waterpump seals
1 x GM Crank Bolt
1 x GM LS2 Timing Chain
1 x GM Oil pump pickup O-Ring
1 x High volume, high flow oil pump
1 x 160 degree thermostat
16 x Patriot Extreme dual valve springs with titanium retainers
16 x 7.400 inch chromemoly hardened pushrods
1 x 25% underdrive crank pulley
1 x New serpentine belt
1 x tube of Red Locktite
Good luck on your choise
#34
I have 02 z06 and have the same goals. I am looking for dependability and high high 10's or low 11's. I went with eps with low 600's lift 230's duration on 112. Thats what they sugested I used. I am running kooks 1 7/8, stock ti's, fast 90 to be hopefully ported by mamo, ati pulley, quality valvetrain, blackwing intake, oe 90 tb. I am looking at mid to late april to get all parts in, I will let you know how it does.
#35
![Angry](https://ls1tech.com/forums/images/icons/icon8.gif)
421.6/dynoed/Tuned @ ECS rear wheel in LS1/ Comp cam 230's/620's/114. Stock 3.42 rear, long tubed, cats, corsa,veraram. Choppy idle, surges under 1000 rpm, runs strong through the gears. Have changed driving habits, ECS rec 4.10/coming soon. Sorry, but it seems you need to use the camera on your phone to make the data cut-off
