Stock Crankshaft Material What is a 01' LQ4 6.0L crankshaft made out of? I know there strong, but are they cast, steel??? |
Cast. Who did the machine work on the engine in your sig? I'd like to check the car out sometime. |
My motor wont be built till this winter. Engines Unlimited, right here in Strawberry Point. He does all my machine work, and he have an engine dyno. |
Cast? Really?? How can they be so strong than??? |
It is CAST....Nodular Iron |
^ I was just about to say. Will support good power, the issue you will see is either pistons or rods failing before the crank does. |
© 2024 MH Sub I, LLC dba Internet Brands
