Bent Valves, where to buy new?
I bent 13 out of 16 Valves on my 03 Z06. Does anyone know where i can get a set of replacment valves for my 243 heads?
most performance shops that port heads should be able to help you out. i have had numerous 5.3L heads ported and i usually pay 50 bucks extra for them to put the bigger ls1 valve in them when they do the valve job.
Like msydow said, most performance shops should carry the valves, You can also try Texas Speed, they have a selection of valves. You can even order them from GMPartsDirect.com if they are stock size valves.
