size tap for oil pan i might have over tightened the oil pan to the chain cover and just want to make sure because there is a little oil coming out |
Are you talking about the oil pan to front cover bolts? If so, those are M8x1.25. |
yes, are the others different... and those are the ones that connect to the timing chain cover?? |
Dwayne, when I put mine together this time I put blue RTV on bottom of TC cover and a little dab on the corners of the oil pan and no problems now. When I did the last cam it leaked so I did this to fix the problem. |
yeah its kinda leakin out the corner.. thanks, ill try that |
© 2024 MH Sub I, LLC dba Internet Brands
