will ls3 pistons work in my lq9
i may have to bore out my lq9 and was wondering if the 6.2 pistons will work with the stock lq9 rods and crank .all i can find are forged pistons as replacements that are all 600$ range there should be some cheaper stock replacements that are .30 over or so any ideas?
IIRC the general increased the bore to 4.065 in order to unshroud the 2.165"
intake valves for a final displacement of 376 cubes. Have the block sonic
checked to check for core shift and a competant machine shop can offset
bore to center in the casting. Actual material removal is .0325. Rebalance
crank as necessary.
crank as necessary.
my block is at a machine shop waiting for there call tomorow or tuesday.he will let me know foresure if i need to bore out walls im sure i have to.but is this a good idea or shuld i just buy 30 over pistons i dont want to be maxing out cylinder walls on the boring ?and does any one sell pistons a little cheaper than the forged ones?
