Can i reach 450 rwhp on pump gas with my set up ???
I want to know if you think that i'm realistic or not.
My set up is a LQ9 factory short block with MS3 from Teaxas Speed ,fully ported 799 with factory valves, ported weiand with 85 mm TB, 55 lbs injectors accell , 1 3/4 stepped to 1 7/8 long tube headers, 4 " mufflex exhaust , 85 mm MAF , fast toys air lid and SSRA true TH400 trans and 8.8 in the back with 4.10 .
I have a good tuner and the car going to be tuned in a Mustang Dyno with load control. Any advice welcome !!! Thanks guys
Yes know it and i going to use a 4000 stall.
I going to eat as much material in the inside , the runners and bore the tb opening.
anything you think that i can change in the set up that can make me reach that goal.
What happend is i have those injectors from a pass project and i going to use them here. As soon i reach the goal on pump gas them i going to hit it with 175 shoot.
