help with cam WWhat ls cam to put in 5.3 with the most gains, sound, but still streetable??? Help asap |
224r or 228r |
I wanna go ls1 hot cam or ls3something like tht, ???? Not a comp or crane? |
comp cam lsr cams are good lobes.you need to talk to a cam company rep and tell them every thing about your engine build..what heads do you have on the 5.3 ? |
Take a look at the Engine Power Systems website for some options. |
I have stock heads, I wanna cam it, the later on maybe do a lil head work nothing much man, id really like to run a ls cam tho, leave u heard of a ls1 hot cam? |
sounds like you want more of a daily driver friendly cam......tr220, proven on 5.3s and easy on the springs for longevity....... |
Ok man, so who makes this cam |
thunder racing |
I looked that cam up , seems like a pretty good choice, another guy told me a Texas speed torquer v 2 cam??? Said it was also daily driver friendly, what springs should I get ls 6???? |
Originally Posted by Whiteaw57
(Post 15481728)
224r or 228r :hijack: |
A torquer is a bit larger for a dd 5.3 imo. I'd go 224r.. Ls1 hotcam is a waste. |
Ok man, ill check out that one! Um what springs would I need |
Something that will handle the extra lift. A common choice is either the patriot golds or the patriot gold extreme springs... good for 0.650 and 0.660 respectively. usually around 240-270ish or pick up new from people on here anywhere from 200-250 :) with retainers and such... |
O ok man, good deal, ima getn ready to order them, still debating on a cam yet, hard decision I wanna do this one time! U know |
I just order my cam today I went with a Tsp 228r on a 110lsa for a dd |
I agree with Lemons12. |
go to either TSP or thunder racing website and look at complete cam pkgs for under $600.consider the tr224 or the TSP 224r.the EPS lobes are a little better then the other cams listed,Geoff worked for thunder racing then started his own company.you can also contact Patrick-G for a EPS cam.you can use comp cam 918 springs for most cams under .600 lift. PAC 1218 or 1518 springs are a little better. |
Ok man well im almost positive im going with the v2, I know the 7.4 ps/rods, and PAC 650.s, ima try it man hope for the best, I wanna be streetable. But also wont to leave lil room for head and intake mods |
© 2024 MH Sub I, LLC dba Internet Brands
