Oil pressure drops at high rpm
Would a bearing going out cause these symptons? I did just have my oil pump pressure relief stick wide open before this happened and oil pressure dropped. Thats why it has the tsp ported pump in it now. I talked with TSP today ,they were leaning towards a bearing, but the thing that has meet as it doesnt do it if I hold it at 6600 rpms, only if i floor it up there, maybe its the higher load?
I would be surprised it's a bearing if you don't have any other symptoms. (noise)
As was suggested, cut open your filter with a pair of sheers. See what you find.
A bearing should be showing more of a pressure loss at idle than rpm like that.
As others have said, you're probably facing a thrust bearing issue, or maybe you'll luck out and find out it's just because you're running it too low on oil. Either way, I seriously doubt your oil pump is at fault.
#33
Check your crank endplay, if you don't know how google it, or pay someone to do it. Thrust bearing failures will not make noise. I know I've had one. Wanna see?
https://ls1tech.com/forums/racers-lo...ew-engine.html
#35
Doesn't work that way. The crank will rest/rotate is a position where pressure is normal. Under load it will push and that's where you see the pressure drop. When load drops, it assumes its normal running position and pressure returns.
#36
op: it appears you've smoked a bearing. especially if you have flakes in the filter. low/no oil pressure, even for a second, will do a lot of damage.
01ssreda4: i assume you had the telltale sign of oil pressure slightly dropping upon wot, then going back up when you let off - so you checked the endplay? if not, what prompted such an action?
#37
Well I called a local machine shop, I asked them for a ballpark figure for basically all new bearings, redo the heads, guides, seals, new cam, new pistons, they said max $3000. They charge $130 to do the crank. I see short blocks for $3500 so if I dont need everything, it should be cheaper than the short block.
What do you guys reccommend? short block, long block or fix the one I have? I am trying to keep it at a minimum but if I have a chance to upgrade heads for a reasonable price, that would be great.
#38
If the thrust surface of the crank is trashed then the crank is a paper-weight. Welding it and refinishing it may or may not hold and its not worth the risk. Get a good used crank and they should be able to assemble a short block for you for about 1K.
#39
So can I check crank end play with the motor in the car?
Does anyone think the oil pump is sucking the pan dry at high rpm? Just seems odd that when I put more oil in the car, it helped a bunch as to how low the pressure dropped and how often it did.
