Should I Stroke It? (383cid, you sickos)
Old 11-07-2011, 07:44 AM
W es 6's Avatar
Default Should I Stroke It? (383cid, you sickos)
Well, really my question is this: If I do stroke it to 383, what heads would everyone recommend to go along with? I don't want to spend $2k on a set of heads, more like $1500ish at the most. Ideas?
Old 11-07-2011, 07:55 AM
always faster's Avatar
I got some PRC LS6 2.5 cnc on my 383/11:1 CR and it made 478whp and 424 wtq on a very conservative tune (12.6 AFR and 26 degree max )
Old 11-07-2011, 08:08 AM
mike c.'s Avatar
NO. Use Trick flow. My boy has a 383ci 11.6 compression with trickflow 215 heads,had a stock fast 90,slp 1 3/4 headers ,stock centermount catback from his ss,12 bolt,4.11's,m6 car and a healthy cam. he procuced just over 500hp on the same dyno i go to and my 402ci was working hard to out pull him. He has up graded to kooks and a mammo ported 102 but no new numbers cuz his clutch went. when it cmes to heads,you get what you pay for.
Old 11-07-2011, 08:34 AM
DaFireMan's Avatar
I agree on the statement that u get what u pay for but dont overlook the trickflow as cast 220's. They work very well an only put down maybe 8 less then the 215s for about your price range
Old 11-07-2011, 11:18 AM
zacht's Avatar
yeah. gotta remember an engine is an air pump...
build it slowly so you dont have to budget so hard!
Old 11-07-2011, 12:46 PM
King Nothing's Avatar
West coast racing cylinder head stage II 243's
Old 11-07-2011, 06:23 PM
batboy's Avatar
For your budget, the Texas Speed stage 2.5 LS6 heads would be my pick. If budget was not a concern, the Trick Flow CNC 215cc heads would be great.
