Rocker Arms to replace YT Ultra Lites?
have you contacted YT? i had one break earlier in the year, and chances are yours was from the same "bad batch". i contacted YT directly and they sent me out an entirely new SET at no cost and was here in a week. no questions asked!
There are a number of reasons why the rocker may have broke, none of which have to do with the rocker. You may want to check a few things before putting money into rocker arms.
1. Did you set the rocker wipe during installation?
2. What is the retainer to valve seal clearance?
3. What is the pushrod to rocker clearance?
4. What is the rocker to retainer clearance?
5. What is the coil bind clearance?
6. What is the pushrod to head clearance?
This makes me wonder about the "bad Batch" of 2009. Maybe it is more to do with proper setup, which makes me wonder why YT doesn't improve their installation instructions.
I was thinking stockers with the comp bearing upgrade. I hear much more about problems with aftermarket rockers breaking than oem, although bearing failure does happen (but rarely). The comp bearing upgrade with the stock rockers seems like a good compromise if you are not looking for 900hp and the price is right. That is my plan at least.
Yes,I set the wipe patterned and got it centered,with about 1/16" wipe.
Don't know exactly, but I did take it through it's full range of motion with checker springs on it, and i do know it was more than 1/16".
Don't know exactly, but I did take it through it's full range of motion with checker springs on it, and it looked good. With no signs of wear on PR's or rocker body.
Good, (about 1/10")I checked the seat height with a spring seat micrometer, and shimmed it to the recommended spring seat height according to PACs specs for the 1521 duals.
Don't know exactly, but I did take it through it's full range of motion with checker springs on it, and it looked good. With no signs of wear on the side of PR's[/QUOTE]
Any opinions on the COMP Cams Ultra-Gold™ Aluminum Rockers, the Crane Cams Gold-Race aluminum rockers, and also the Lunati Voodoo LS Series Adjustable Twin Shaft Rocker Arms?
FYI, I'd like to get my car back on the road very soon!
Also I just found out that the Recommended maximum spring pressure is 425 lbs for the YT ultra lites.
Even if they do wear the guides faster they don't break like alum ones do. They are lighter.
Lots of RPM issues are fixed by installing stock rockers.
If I had to put guides in after 75k I would not be upset but having to keep a spare in the trunk and replace them every 8 months I would be pissed.
My valve train guy is not had customers calling with problems and he has guys putting lots of miles on stuff.
Tim
Tim
