408 won't start I recently installed a gen4 408 into my 2002 ws6, I am using the ls1 wiring harness still. I have the correct 24tooth reluctor wheel, but i keep getting a crank position sensor error when I try to start it, I swapped the sensors twice to double check and make sure it wasn't a bad sensor. The tach works for a split second while trying to start it, then does not work again until i clear the crank position sensor code p0335. Can't get it to start, any ideas? 408 11.5cr ls3 heads ls7s cam (tsp) mail order tune from tsp |
what type of cam sensor setup do you have? ls2? |
cam sensor is set up correctly as far as i know, x1 wheel and the wire has been crossed over for the sensor |
2 Attachment(s) do you have this for timing |
yea thats what have, with the outside two wires swapped on the connector |
https://ls1tech.com/forums/generatio...ont-start.html I found that in a quick search and figured it was worth a shot. I would focus on the crank sensor because the car will start without the cam sensor. It may pop and backfire while cranking but it will run. |
I had tried something similar to that last night with no luck. Maybe I spaced out the sensor too far? |
| All times are GMT -5. The time now is 03:54 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
