Has ANYONE tried the Patriot Predator Heads?? Hey guys..... has ANYONE tried the fairly new Predator heads from Patriot? I recently picked up a set and am starting to have second thoughts because no one on this forum seems to have tried them... dare I be a guinea pig ? Backing up a bit, my decision was based on talks with the guys at Patriot, reading an article on the heads through GMHTP, and seeing the sale price.. I was sold on them.. Physically, the heads look pretty good and I don't see anything obvious about them that makes them look "cheap". Also, I hope to have the actual flow numbers on them sometime this week, and will post on here. Anyway, did I make a mistake in my limited research before chosing to go with these heads? Any thoughts are appreciated! |
Post pics! |
4 Attachment(s) see attachments below.... in my opinion, they look pretty dang good. Also, just got off the phone with Patriot, I hope to have my actual flow numbers in today. For reference, they had stated that they just bench tested the same set of heads for another customer and it flowed 28xcfm at .500", 294cfm at .550", and 302cfm at .600" ... pretty good if you ask me... still trying to get more details on their test setup though to confirm that it's valid data. |
Originally Posted by AFish66
(Post 15674401)
I picked up mine on sale for just under $1400 shipped, straight through Patriot. That was the thing that attracted me the most since I had never originally budgeted a set of heads for this project. |
Are they an aftermarket casting? Hey, you know what, I commend you for trying something different. The only way to know if they will be worth a shit is to try them out, get some dyno numbers and track times, and let the rest of the LS1tech community know. You never know, these heads may be the next big thing and it will all be thanks to you for taking a chance on them. |
Originally Posted by Rise of the Phoenix
(Post 15675076)
I have used these heads in a N/A application and they performed VERY poorly. :( Real heads like AFR/TFS perform on the street/track/dyno. |
Id send them back and get some touched up as cast 220's! |
All I will say is there is a reason most guys run TF, PRC and AFR aftermarket heads on here. That's very cheap for an aftermarket casting and I'd be careful before you put them on. Patriot wasn't even on my radar when picking out heads. |
Op just try them out they could work well, listen there is so much BS on the internet these days, guys will tell you that they suck just because there not afr / tfs etc. Like I said try them out and get back to us on how they do. |
Yup, Patriot's were all the rage here 5 or 6 yrs ago, but now you couldn't give them away. Funny how some can justify spending an extra grand for heads that make 10 HP more. I guess it's OK if you can win it back racing. But most cars here are street cars, and for a street car they'll do fine... |
Omg! If no one on ls1tech likes them or runs them that means they suck! |
Originally Posted by JPH
(Post 15675283)
Originally Posted by Cosmos
(Post 15675948)
(Post 15675948)
I can somewhat agree with you Phoenix on the bandwagoning on here, but either way I appreciate all of the feedback. I plan on running the heads, mainly because I can't justify the extra $$$$ to go with the AFRs or Trick Flows right now. |
(Post 15677975)
I can somewhat agree with you Phoenix on the bandwagoning on here, but either way I appreciate all of the feedback. I plan on running the heads, mainly because I can't justify the extra $$$$ to go with the AFRs or Trick Flows right now. As far as your heads, you've already bought them, so just run them and see what happens. I understand what you're saying regarding spending the extra money on the AFR or TFS heads, but if you're patient, you can find them used in the classified section all day long for $1,500.00. Plus, new, the TFS 220 heads can be bought for under $1,700.00. That's the route I'm going when I pull the trigger on some heads and cam. I've done a ton of research on the TFS 220 as cast heads and they are proven performers. |
Not to jump off topic but I do agree that the band wagoning here is crazy. It's gets kind of ridiculous sometimes. AFish66, those heads from Patriot I believe are the exact same heads that are going on my car. You must've called right after me cause Steven told me they were getting ready to ship them out and just got the flow numbers. I called Steven about four weeks ago when I was looking for a set of heads and he was one of the most helpful people I talked to. His heads may not be AFR or Trick Flow, but with great customer service I don't mind taking a loss in a few hp if someone has taken time to really help and make sure I get what will make me happiest with my car. That in turn makes it worth the purchase. I also think that they will be a definite bang for the buck! I'm also getting my cam reground from Bullet Cams to go with these heads and hopefully I'll get some pretty decent numbers. It's gonna be a lil while before I get my car dyno tuned but when I do I'll post up numbers and be a guinea pig too lol |
Here ya go: http://www.gmhightechperformance.com...two_three.html It also depends on the cam that your matching with. They should perform really well for street use. Good budget heads though. |
I seen a 496 rwhp ls1 car a while back in the dyno section with some "touched up" as cast 220's.. I was quoted 1900ish from a guy on here to touch them up and for the powdered valve guides. |
© 2024 MH Sub I, LLC dba Internet Brands
