1.8 Rockers, will I have PTV issues with my 243's also are comp 918s ok?
I think I want a bit more cam but don't want to pull out my EPS I just installed this fall.
My cam is the EPS 226/234 113, 598/601
I have stock 243s on there. Will I have piston to valve issues?
Also will my comp 918s be ok?
The lift you have now is plenty for your stock 243's.. Adding 1.8's will up the lift, but wont change the duration, which is where PTV clearance comes into play.. If you want "MORE" cam, you need to look at more duration.. I would toss the 918's for a set of PSI beehives or a good set of duals.
I also wouldnt ever change to a 1.8 rocker on LS engines, unless the lobe being used was designed for a 1.8 rocker. Lobes today are aggressive, and upping the ratio would most likely cause valvetrain instability. The only cam Ive seen 1.8s work well on were stock cams and lobes desinged for 1.8s
918s are perfect in this situation. Duals, while they would physically work, are not the most correct for this application.
While changing rocker ratio doesnt add duration on the seat, it absolutely changes duration after the valve leaves the seat. Typically about 2-3 degrees @.050, while not huge, it does change!
And read Sweet10's quote:
Originally Posted by John Lingenfelter
The world's best cam combined with a poor set of heads will produce an engine that's a dog. But bolt on a set of great heads even with a poor cam, and that engine will still make great power.
