Streetsweeper with Terminator heads? Just wondering if anyone has run this combo? Looks like that is what I'm going to put together in the next month. The heads are milled to a 58cc. Depending on how far out of the hole I am when I get the block back, I should be around 11.2-11.5 SCR and 7.3x DCR(5500ft) Do any of you see and issue with the combo? If anyone has run this set up or close let me know the positives and negatives you have seen. Thanks for any info. |
Bump... |
No one has any advice? |
I doubt there is anyone on here with that combo, but the Street Sweeper cam is fairly popular, just not with those heads. I'm sure it will be a good combo through. Are you planning to fly-cut? At 58cc, unless you have dished pistons, you're going to have to flycut. Have you done much research on the Street Sweeper cam? It's an Ed Curtis cam, so you know it's a great cam. Good luck. |
I have 3.2cc valve reliefs in wiseco pistons It should be fine but I will check it when I get the block back from the shop. I'm hoping the combo does well but we will see. I'd like to see 430-450rw through the 9. |
I ran the streetsweeper with stock 853 heads, I am sure with the proper intake and exhaust setup you will see 450 rwhp. I did 405 with a BBK and LPP longtubes |
It will be a 90/90 also but the 9 sucks up alot of power. |
© 2024 MH Sub I, LLC dba Internet Brands
