243's shaved .020 ballpark cc? I am having my heads reworked and trying to come up with my new compression ratio after having my 243 heads decked .020. its a TSP Short block with Diamond -2cc pistons. Any clue? |
Chambers will be about 61cc after milling .020". Assuming pistons out of the hole .005", 347ci build, and using GM MLS gasket your static compression would be about 10.9:1. |
thanks! Matt, just for grins, you guys don't have/sell any used Ls6 blocks do you? I saw you had new ones, but looking for a cheaper alternative for replacing one with an out of spec Bore... |
General rule with this bore is every .006 = 1cc.. |
Resleeve your out of round cylinder? |
Originally Posted by eric1h
(Post 15879567)
| All times are GMT -5. The time now is 12:43 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
