243's vs 853's
Old Apr 8, 2012 | 09:26 PM
njmaster's Avatar
Default 243's vs 853's
I currently have the stock 853's on my car, but i purchased a set of 243's off of an LS2. I will be doing a cam swap, so i went ahead and had the heads ported. They picked up 30cfm at .500 lift over stock 243's. I am curious as to how much hp these heads are worth over the stock 853's?
Old Apr 8, 2012 | 11:10 PM
studderin's Avatar
30-40 without milling them a bunch, with a normal intake.
Old Apr 9, 2012 | 07:58 AM
MonmouthCtyLS7's Avatar
Stock you'll see about 15 hp over your Fbody heads w/ the 243's...obviously more with port work
Old Apr 9, 2012 | 08:17 AM
njmaster's Avatar
Thanks guys. These will be installed with an F11 cam and I already have an LS6 intake and LT's. I got the 243's complete with springs and rockers. I will obviously be running an aftermarket spring with the cam, but what about the rocker arms? Are they any different than the stock rockers that came on the LS1? Like i said the 243's came off of an LS2. Which ones should i use?
Old Apr 9, 2012 | 08:22 AM
Your stock rockers are fine.
Old Apr 9, 2012 | 08:35 AM
autogeek23's Avatar
yeah keep the stock rockers. if anything you could do the trunion upgrade come from comp. $134 from Jegs.
trunion: http://www.jegs.com/i/Comp+Cams/249/13702-KIT/10002/-1
heres a write up on how to do it http://www.f-bodyhideout.com/forums/...grade-Write-up
there is a tool but i cant find it
Last edited by autogeek23; Apr 9, 2012 at 08:36 AM. Reason: wrong link the first time
Old Apr 9, 2012 | 08:36 PM
christiandoy's Avatar
243> than 853
Old Apr 9, 2012 | 09:01 PM
Originally Posted by christiandoy
243> than 853
Helpful post right there
