Used 918 springs
Used 918 springs
I bought my car with 918 springs on it. I know the previous owner and he told me they only have 4-5k miles on 'em. The car has the stock camshaft now, should I replace these springs if I put a somewhat small cam in it?
218/229 .560/.560 113
You should be ok. Just make sure they are the blue stripe 918s. I learned that lesson the hard way.
If you want some titanium retainers for the 918s, I think I have set in the garage.
Hell, I have either 2 or 3 sets of 918s.
the blue stripe just means they're part of the "good" batch... the 918s had a really bad quality control issue back in 01 or 02 ... lots were snapping and causing damage to peops motors (dropping valves)... Comp has since fixed the issue and the 918 is again an awesome spring...
Originally Posted by DenzSS
Are they a beehive style spring with a blue stripe? If so, that pretty much identifies them as a 918.
You should be safe with the 918s. They are a hell of a good spring. I'm a bit nervous about .609" lift on a 918, but a lot of the threat to the spring is in the ramp design. Lingenfelter doesn't typically grind lobes that aren't for street use, so my guess is they are ok.
LS1Tech Administrator
Received 1,483 Likes
My set from Nov of '01 is still doing just fine after thousands of miles with my cam. Most of the 'bad batch' springs seem to have broke in the first 200-1000 miles of use.....
Originally Posted by NHRATA01
My Nov '01 918s have 22k miles on them and haven't had a problem. But I would get the blue stripe version just to be sure.
