LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   Degree'n a cam (https://ls1tech.com/forums/generation-iii-internal-engine/1543367-degreen-cam.html)
badazz81z28 May 3, 2012 07:03 PM
Degree'n a cam
I have search and read so many threads, I'm just sick!
Is there a proper kit out there that isnt an arm and a leg for an Aluminum block heads off?
I'm only going to do this once! And yet another $200 tool.
Is it even really worth it? I read too many post where people just install them dot to dot.
flintwrench69 May 3, 2012 08:45 PM
Just depends on the cam specs & if you plan on milling the heads a lot. It would be fairly safe staying under .600 lift & 230 duration if youre not gonna degree the cam.
© 2026 MH Sub I, LLC dba Internet Brands
