LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   Engine hasn't been started in over a year... (https://ls1tech.com/forums/generation-iii-internal-engine/1551717-engine-hasnt-been-started-over-year.html)
Dead Hook May 30, 2012 11:35 AM
My project has sat for just over a year. I'm installing a rebuilt trans in the next couple of weeks and wanted to know if I need to do anything to the engine before starting it?
VandykeT/A May 30, 2012 11:41 AM
You could put a little oil down in the cylinders or you could pull the valve covers off and splash some oil on the rockers but honestly I think it'd be fine to just fire it up. I'd change the oil and maybe the plugs.
Dead Hook May 30, 2012 11:59 AM
Thanks. I didn't expect to have this car sit for so long without starting it. It has been sitting in my garage in sunny California so for my lack of not "winterizing" it, I hope it is OK.
I'm not familiar with these LS1's much. I take it you can't prime the system like on a old chevy or f*rd? Those were easy with a drill and shaft tool to spin the oil pump through the distributor hole.
BrntWS6 May 30, 2012 12:18 PM
It'll probably be fine as is. I've let mine sit for 8 months in storage and it started right up.
BlackScreaminMachine May 30, 2012 12:35 PM
Would be good to build up the pressure but like said should be fine. All depends on how over kill you want to get.
Dead Hook May 30, 2012 12:46 PM
Better safe than sorry. What's an easy method to build pressure prior to firing?
RedRocketZ28 May 30, 2012 01:09 PM
Unhook the coil packs so it doesn't fire and turn it over.
© 2026 MH Sub I, LLC dba Internet Brands
