recommendation's for start up after 4 years so my question is the car has been sitting for 4 year with new oil and filter in it but it has a few quarts over in it currently, i was wondering should i just drain some of the oil out and runner like seafoam or something threw it then change the oil ? idk if it matter but the type of oil in it is gtx high millage green bottle 5w-30 or 10-30 i cant remember been so long |
Originally Posted by devic
(Post 16486055)
I'd change the oil out, and pull the fuel pump fuse. crank the motor over a few times to prime some oil in the motor and then put the fuse back in and start it up. I do this everytime I deploy for a year. |
the radiator fluid looked good still think i should still change it ? appeared to still be that bright clear pink color, and i changed the intake seals and tb seals i cant really see the others to well and so u dont think i need a flush to run threw it encase of sludge build up ? |
(Post 16486084)
the radiator fluid looked good still think i should still change it ? appeared to still be that bright clear pink color, and i changed the intake seals and tb seals i cant really see the others to well and so u dont think i need a flush to run threw it encase of sludge build up ? I am not saying that you can not start the motor the way it is now. I am just saying that after 4 years of sitting still you might start to notice a ton of leaks developing all along the drive train due to seals decaying. That is not to say that they are bad either. I would just eyeball them all and if need be, replace them. |
the oil pan gasket i changed out bout a year b4 it sat, and i just replaced the transmission pan gasket an filter, along with intake and throttle body gaskets and prob 2 years b4 it sat i changed the transmission front and rear seals |
I see no mention of the fuel system...After 4yrs, you can about bet the farm, that the gas has turned to crud, the injectors may well be gummed shut, and the tank may have a load of crap formed in it, too. Time to clean it up, B4 trying to start it.... |
Originally Posted by Old Geezer
(Post 16486122)
i was going to disconnect the fuel line and pump out the old gas, looks like a fun time trying to drop the tank, i had dropped a tank in a 86 one time that was no fun lol is there a guide some where on here to drop the tank, cause dont u have to drop the rear end and sway bars ? |
and as far as the injector how do i go about cleaning them with out damaging them |
(Post 16486143)
i was going to disconnect the fuel line and pump out the old gas, looks like a fun time trying to drop the tank, i had dropped a tank in a 86 one time that was no fun lol is there a guide some where on here to drop the tank, cause dont u have to drop the rear end and sway bars ? I never said it was fun or easy to remove.
(Post 16486146)
thanks for that seafoam link very helpful i was kinda nervus bout using it but now not so much |
(Post 16486238)
Originally Posted by Decadence75
(Post 16486170)
No, you do not have to drop the rear. You first release the pressure in the fuel system then drain the tank. Put it up on some stands, prolly at least 18 inches up to give good clearance. You will want to remove whatever cat back you have installed for this. Take off the tank heat shield. Remove the fill pipe supports. Disconnect the fuel return and evap quick connects. Disconnect the feed line at the fuel filter and cap all the lines to help stop fumes for you and to help stop dirt for the tank. Remove the body clips for those lines. Disconnect the sender and pressure molex connectors. Now you need to support the tank with a jack or a stand..something to keep it in place and from falling on you. Unbolt the straps holding the tank up, and them ease the tank out and down from the supports. Have fun cleaning it :) I never said it was fun or easy to remove. Seafoam. https://ls1tech.com/forums/general-m...-your-car.html You guys are crazy haha!! Drop the gas tank and try to clean it because the car sat for 4 years!? OP, that is no cake job to drop the fuel tank. Just pull the ignition relay out, crank the motor over a few times, replace it, and then fire it up. After it is warmed up I would change the oil and that's it. There is no need to change your coolant. I do agree you need to do something with the fuel, I just disagree with dropping and cleaning the tank. Just fill it up with gas and put a can of either Seafoam or GM Fuel Injector Cleaner (works great) and then go out and enjoy your car. |
Originally Posted by lt1pwr1
(Post 16486412)
You can siphon all but about a quart of fuel out of your tank from the filler. You should do this before dropping the tank anyway, but I would not drop the tank. Siphon as much as you can, refill with fresh. Add some fuel dry, whatever its called. I'd replace the fuel filter, turn on the ignition and bleed the fuel system at the rail to get the fresh fuel to the engine and then fire it up. . .I'd change the oil first too and prime the system like was mentioned. . .but I would not drop the tank. That is an enormous pain in the ass and IMO you can achieve 95+% just through siphoning well and adding a fuel drier. You surely will need to seafoam if you've left fuel in it this long. The fuel probably varnished your injectors years ago. You will probably have some bad seals, I'd just replace them as they are identified. . .come to think of it maybe you should just replace the injector orings since they can really screw you over (allowing rain to leak in and hydrolock the motor). When you do that, you could clean the injectors directly. . .something to consider anyway. |
I'd suggest..
(Post 16486146)
Here is a step by step list of what I would do. 1 ) Fuel additive to dry out the gas in the tank. 2 ) Change the fuel filter. Have a spare filter for later. 3 ) charge the battery. 4 ) Pull the plugs and clean them. Leave them out. 5 ) Add Seafoam or some other top cylinder cleaner/lubricant to the oil. 6 ) Roll the motor over by hand to make sure that there is no problems like a rust siezed piston. 7 ) Re-install the plugs, pull the fuel pump fuse. 8 ) crank the motor over till the oil pressure gauge reads normal. 9 ) Re-Install the fuel pump fuse and attempt to fire the engine. 10) If it fires let it run for several minutes and get completely warm. If it doesn't fire trouble shoot and fix. 11) Drive the car around the block a few times to get it up to temp and make sure it runs and shifts. Listen for odd noises that may mean problems. 12) look for leaks, don't go to the time and trouble of changing seals unless they are actually leaking. Modern seals are not as prone to deteriorate as the ones on old 60s and 70s cars. 13 ) Change the oil and filter. 14) Add a tank of fresh gas and you are done. Thats how Id do it. I wouldn't worry about fixing problems untill I found them. |
My car had the radiator fluid, oil & filter, and fuel filter changed prior to sitting on stands for three years while overseas. I also used Stabil in the tank. Memorial Day weekend I returned to the storage facility it was kept dropped in a new battery and it started right up. The car has under 15k on her FYI. I inspected the underneath for any leaks and found none. I dropped the car added fuel cleaner and fuel and drove it 200 miles where it sat a month before being driven 800 miles where it currently sits. There are still no leaks to report. Performance wise it seems to pull as hard as before but after three years of 40 and 60 kph speed limits in Japan I am not 100% sure. I am not saying this was the right thing to do but it is my experience. |
well i got the seafoam for the tank and new oil, the motor turns over by hand pretty well, yeah i was really not wanting to drop the tank if i dont have to. so u think if i just disconnect the fuel filter turn the key to drain the system, install new fuel filter then add seafoam, plus full tank of 91 or higher and all should be good ? |
| All times are GMT -5. The time now is 05:58 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
