Solid Roller guru's inside please Current setup: 382 stroker with LS6 intake, GTP SII heads, Long teubes with true duals, etc. Now for the point at hand, I would like to go with a solid roller setup and am looking for some advice for a good cam to run with N2O. Not really worried about streetability at this point, just performance. All help is appreciated. PS the car is a A4 right now, planning on going to an A3 though. |
Re: Solid Roller guru's inside please Dang, cant get no love around here lol. Cmon fellas any advice other than tellin me to get "F"ed is appreciated. <img border="0" alt="[worship]" title="" src="graemlins/gr_hail.gif" /> |
Re: Solid Roller guru's inside please Your best bet would be to get in touch with one of our sponsors that have experience with solid roller setups. Solid roller cams don't quite "spec" out the same way as a typical hydraulic roller. Besides coming up with some basic lift/duration numbers, you will want to put a lot of thought into the specific lobe profile, and how that will work with your current/proposed valvetrain components. Thunder Racing and Futral Motorsports have been doing a lot with solid roller cams lately, so I'd start there. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> |
Re: Solid Roller guru's inside please Thank you very much George. I appreciate your input and have sent an email to Paul at Thunder. Mike |
Re: Solid Roller guru's inside please I have done alot of research on this topic. As a matter of fact I ended up having custom parts made. I'm involved with a tool & die shop. If you are interested I can put a package together that will work with stock valves and giudes. The package includes: Custom springs Custom spring ID locators(Bottom) Retainers correct spring seat cutter Springs are double springs with an installed hieght of 1.800. They coil bind at 1.060. With .060 clearence they will support .680 of travel. They have 225 lbs on the seat and open is 515. The only machining required is to have the seats cut with the included cutter and to have the guides cut down .100. This is to have adequete clearance between retainer and valve seal. Locator is designed to work with LS1 Seals. Not LS6 type. Theses springs are special since they are small in Diameter. They will not break into port of an LS1. The LS6 is very close. The Id locators are a slip fit on the guide and are heat treated A2 steel. The id locators and springs are the key. Otherwise to use traditional off the shelf parts(Comp,Crane,Lunati,Manley,Isky,Crower,Ferea, we checked them all)you will have to change giudes, use a traditional 11/32 stem, and because of the large od springs (1.57) shim up the spring and run longer valves. If all this seems foriegn to you call a vendor and buy a set ready to go. They have thier own way of crosing the river. Or call me 954-233-6363 Randy |
Re: Solid Roller guru's inside please Thanks for the info Randy, this project is gonna be on hold for a bit until I get back, but I plan on keeping all options open right now. Mike |
Re: Solid Roller guru's inside please Randyn, Do you have a shop in Davie? |
Re: Solid Roller guru's inside please If you want Solid roller, I think Alan Futral is the man right now. I will know in about when my setup is all in and poundin the street <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> |
| All times are GMT -5. The time now is 10:41 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
