How To Remove Knock Sensor's
How Do U Remove The Knock Sensor Do U Have To Have A Specal Tool To Remove Or What I Am In My Grage Installing A Cam Right Now And I Need Help W The Knock Sen To Continue W Work So Please Help Asap
Thank You
Eric
Thank You
Eric
Thank You
Eric
Thank You
Eric
I use a pair of pliers or channel-locks to squeeze the wide sides of the plastic to disconnect the harness from the knock sensors. It's kind of like those pill bottles where you need to squeeze opposing sides of the lid, and then turn - except you pull up instead.
I then use a large socket & extension to remove them. I don't recall the socket size.
Hope that helps...
