Grand Am Camshaft & serious valve float Hey Guys Just running this camshaft with the following components and getting valve float at around 6600rpm. comp r lifters ( 1/8 preload ) comp 921 springs comp pro mag 1.85 rockers titanium retainers manley 2.02 & 1.6 valves ls6 heads I see people post that there car with this cam revs to 7500-8000 rpm What springs ,rockers ect are they using ? We have installed this cam with 4 degrees advance for good torque but thinking of going back to 1-0 advance. Will try and run some 1.75 comp rockers instead of the 1.85 and some 918 beehive springs to help the valve float. Is their a another cam that would be faster down the 1/4 mile ( Do not want to go smaller & have plenty of room for bigger cam) P.S It is still making power upto 6600 on the dyno. Cheers & hope you can help :cheers: |
I put some thoughts in my thread for you. good luck. |
© 2024 MH Sub I, LLC dba Internet Brands
