about to order a tsp lq9 408 need help
I called tsp explaining i want a real bad *** daily driver. One of my biggest concerns being reliability and life expectancy of the motor. They suggested their forged 408 lq9 with prc 237 heads and a ms4 cam. My question is what are your thoughts on this setup and choice in camshaft. He seemed like a really honest guy and suggested I just stick with the basic package as everything else is pretty much overkill and a waste of money in my case. This is possibly one of the only times ive seen a company try to save me money. I'm not looking for a race car just dont want to regret not going big and doing it right the first time
The MS4 is going to be pretty tame in the 408 since the cubes are bigger but you will still have plenty of power there. Im pretty much going to use the same setup on my 408 for my dream build just the cam choice has me thinking on what to get.
The iron lq9 is cheaper and a direct bolt in pretty much. The aluminum ls1 can only go as big as 383 and any other style block will be too much cash and time to swap. Plus the iron is soo much stronger and only like 60 lbs heavier. Pros really outweigh the cons. Also I found this exact setup in a gto putting out 500 rwhp on YouTube so it seems pretty nasty just cant get an idling sound clip
I think the consensus is that it's closer to 80lbs heavier and it's on the nose of the car.
But you are correct the iron is cheaper and that might still be enough to be the deciding factor.
Talk to Aaron, he goes above and beyond to get you set up straight. We had some hiccups with mine and wasn't even their fault on some and he made it right. I wouldn't talk to anyone else but him there. Stand up guy and b/c of him I've got a great motor sitting on an engine stand waiting to go in my GTO.
I would think if it`s a street car, the extra weight of the iron block is not that important. I just had a lq 408 installed in my car and it made almost no difference in how the car drove, except for the fun factor of the extra HP & TQ.
No difference in dropping and ls2 vs lq based motor in an fbody.
Both can make 4xx c.i. motors.
Iron blocks are roughly 105-115#s heavier. Decide how much 10rwhp is worth to you and if the price difference is less than that, go aluminum.. If the price difference is more, go iron.
I personally would go a completely different route with a 408 build.
What was the shortblock price?
It was explained to me like this.......roughly 100 pounds of dead weight as an example. When you are serious enough about performance that you are looking into built motors you'll understand that there comes a point where losing weight is cheaper then gaining hp for going fast and OVERALL vehicle performance. If you're gonna drop the engine in and forget about it, then go iron. For overall vehicle performance seriously consider aluminum. Lets say you add the iron block, then decide later down the road you want the car quicker and realize your car is a little bloated around the waistline. Lets take some weight off.....lightweight carpet, delete airbags, reduce interior, delete AC, add tubular k member, tubular bumper supports etc etc. What amount of A. money or B. civility of your car have you given up to get that 100 pounds back? When you start buying stuff like $500 k members that save 25 pounds or $500 bumper supports that save 40 pounds, that 100 pounds you added now starts to get more relevant.
