TFS Head spring work on stock casting 241's? I got a set of TFS springs/retainers and was wondering if I can just use these on my stock heads when I do my cam swap? |
If the springs are duals you will need to change the spring seats/locaters and valve seals...also double check the installed height to make sure the springs are set up properly for pressures. |
| All times are GMT -5. The time now is 06:27 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
