2002 LS1-what trans to use 4l60e or 700R4
I recently purchased a complete 2002 LS1 Z28 motor to include the harness and computer however no tranny. I'm currently in the hunt for a 700R4 or the 4l60e trans, which was originally behind the LS1. MOST importantly can a 700R4 be made to work behind the LS1 and what would it take to make this happen? Fly wheel, torque convertor, computer tweaking????
I know the 4L60e was stock behind this motor. I just like the idea of a non electric trans if it can be done.
Thanks
Thanks
LS1Tech Premium Sponsor
Replacing the factory 4L60E in the car with a 700R4 is just plain crazy and doesn't make any sense what so ever. Strength-wise they are about the same but a 4L60E will just bolt-in and all the electronic plugs would work like they should and you be able to tune the transmission through the tune which is way easier then messing with 700R4.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
What they said above...
and also: the later 4L60E (and the 4L65E) has a 2-piece case (i.e. removable bell housing) which has been shown to be stronger than the previous 1-piece case.
the PCM (which the OP said he has) controls both the LS1 and the 4L60E simultaneously together...
i.e. these three components already fit together without requiring re-engineering.
