LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   NGK TR6's and 75 shot (https://ls1tech.com/forums/generation-iii-internal-engine/1625085-ngk-tr6s-75-shot.html)
HCI2000SS Feb 20, 2013 07:47 PM
As some of you may know I have a complete NX wet kit which is installed and ready to go. Here is my dilemma: Money is tight right now, so i'm looking to just spray a 75 shot right now without changing the timing, and running my NGK TR6 plugs (gapped at 0.040). So basically changing nothing...thus costing me nothing lol! I'll throw the car on the dyno to check air/fuel, and the car is tuned for the HCI combo of course, but that's it. Now i've searched the forums here, called a couple places, and am getting mixed opinions. One person or thread says sure no problem at all, and another says nope...not a good idea. The tech guy at NGK says no good, but NX says no problem lol. So bottom line guys....can this be safely done? I know these plugs are not ideal for nitrous (I totally get that) but see several people doing it...especially on a small 75 shot. So what do you all think?
Oh and one other thing that might be worth mentioning...my compression is around 11 to 1 vs the stock 10 to 1. Not sure if that is relevant, but thought i'd throw that in there just in case
batboy Feb 20, 2013 08:21 PM
That used to be "the" nitrous plug until the non-projected ones became popular. Nowadays I would recommend NGK BR6EF plugs. Can you run the TR6 on a small shot? Probably, if you pull a couple degrees timing. Have I done it? Yes, before I knew any better. Do I recommend it? No.
HCI2000SS Feb 20, 2013 08:29 PM
So how long did you run the TR6's, and what were they gapped at? What size shot were you running? If they were "the nitrous plug" at one point how can they be all that bad then? Thanks for the info man...i'm just trying to learn here :)
batboy Feb 20, 2013 08:34 PM
I ran a 75 dry shot at the time and I ran the setup for a couple years, only spraying at the track. That said, I had a nitrous tune with 3 degrees timing pulled when I sprayed. I believe I gapped about .040" or so. I run .035" gap now with NGK BR7EF (but I'm also running a 150 wet shot). Seriously, plugs are not that expensive.
HCI2000SS Feb 20, 2013 10:14 PM
Yeah I know the plugs are cheap, but I was hoping to just leave it as is and go lol :) Have you ever changed plugs in these cars before? I am new to the LS world (came from the Mustang world) and to change the plugs in this car looks like a real pita lol
dannyz Feb 20, 2013 10:30 PM
I ran TR6 plugs for quite a while on a Zex nitrous kit. Ran about 22 bottles thru on a 75 shot, no problem's at all. BUT, you have heads and cam, so I am betting your timing has been advanced some. So I would say don't do it. The NX guy said you could? Wow. Maybe he didn't hear you say that you have heads/cam in your ride. I can't imagine them saying that it's ok to smack it even with a smaller shot.
I know your on a budget, but if you hurt your engine where will that leave you?
batboy Feb 20, 2013 11:16 PM
Yeah, I've pulled the plugs out many times. It's not all that hard, although it is a little tight quarters. I have a GTO, so the back of the engine doesn't run up under the cowl like the F-bodies do.
Detoxx03 Feb 20, 2013 11:17 PM
Sure you can use the tr6's but don't. Use non-preojected tip plugs. Get some br7ef's (part number 3346) and they will be good up to 150 shot.
HCI2000SS Feb 21, 2013 03:13 PM
I appreciate the info guys! Well I just talked to my tuner (he has never let me down in the last 8 years) and he says with my build I will be fine. He has done countless LS1's, Mustang's, etc...and has a great reputation! I will verify the timing though, and if it's significantly advanced I will change them, but if it isn't I think i'm going to keep it as is for a bit. I'll keep you guys posted ;)
sabersaw30 Feb 21, 2013 04:23 PM
I wouldn't run it without a nos tune.if your tune is real aggressive you will get a lot of spark knock on the juice.Deffinately drop the timing.
mjs1012 Feb 21, 2013 09:35 PM
If it were me I'd wait and get it tuned. Better paying a few hundred for a retune than few grand in a new motor that detonates due to too much timing.
izcain Feb 22, 2013 12:05 AM
seems like for such a cheap item like a spark plug and you can use either with one being slightly "safer" I am not understanding why take the chance?
Just removed the TR6's out of mine and put in the BR7EF's seems to run the same as before but I have a piece of mind. Recommended by a good tuner as well.
HCI2000SS Feb 22, 2013 12:28 PM
I don't want to sound stupid here, but if the TR6's were a decent nitrous plug back in the day, then how can they possibly be all that bad...especially on a 75 shot? I mean I get that there are better plugs, and my timing comes into play here, but if the timing isn't too advanced why would this be a problem? I know it's a projected tip plug, but it is one step colder and they are a copper tip plug as well correct? I'm just trying to find some "real world" reasons as to why this is such a bad idea here. Also would switching to something like BR7EF's affect my n/a performance....even in the slightest? Thanks again guys!
john563 Feb 22, 2013 02:18 PM
i have the same heads as you and use br7ef plugs..doesnt affect N/A at all..on a 100 shot and pull 4deg with harris interface..if idid do a 75 (which i considered at first) id pull bout 3deg...normall rule of thumb is 2 deg for every 50..you could get away with 2 deg pulled...either way id pull timing
dannyz Feb 22, 2013 03:04 PM
Your not sounding stupid at all.
TR6 plugs were the recomended nitrous plug for years untill fairly recently when it was found that the non-projected tip plugs were safer.
BUT, TR6's are perfectly fine, if your timing is reduced accordingly to the size shot you plan to run, up to 125rwhp shot. Some ran TR6's with a 150+ shot w/o problem, but thats running on the ragged edge.
No way I would do that.
But for a 75 shot, like what you want to use, TR6 plugs are fine, so long as your timing is good.
Now, expect to be raked over the coals on this, [once this post gets moved to the nitrous section], but as I said earlier, I ran the TR6 plugs for years on a 75 shot. Most everybody did.
But the "pack mentality" that accompanys a lot of threads on this subject, would have you believe that if you use those plugs, your engine will blow a 8 ft deep crater beneath your car and send debris skyward knocking passenger jets out of the air, lol.
HCI2000SS Feb 22, 2013 05:05 PM
See now this makes some sense to me from everything i've read and heard. Thank you for posting this! So I guess it really boils down to where my timing is at, and weather I get any detonation or not. Any idea on where my timing should be for it to be safe like this?
blacktransam Feb 22, 2013 05:21 PM
There not. PERIOD. I sprayed a 200 shot for years on tr6's on pump gas. 26* of timing. a 300 shot on projected tip TR7IX's. Were talking about a 75 shot here people. Less than a 10hp per hole increase. I'd spray that on stock plugs with out a worry.
HCI2000SS Feb 24, 2013 01:06 PM
That's really good to know! A 200 shot on those plugs is huge from what I understand, so again I can't see why a 75 shot should be a problem at all if my timing isn't like crazy advanced or anything.
Sales@Tick Feb 24, 2013 07:00 PM
I wouldn't do it.
dannyz Feb 25, 2013 01:22 AM
Originally Posted by Martin@Tick (Post 17177032)
I wouldn't do it.
Why is that?
If his timing is good, why not?
© 2026 MH Sub I, LLC dba Internet Brands
