New motor..broken oil rings, ever seen anything like it?
So either the shop gets blamed or the customer and some ones out a lot of money. I'd be calling them getting some kind of good explanation of why the parts failed when it was properly assembled. I mean seriously at 1st I thought this was some one building a engine in their garage that didn't know what they were doing.
Its clearly a parts failure! Call them out on this OR post it all over the web!
The oil ring material is VERY brittle compared to stock oil rings (those are the only other oil rings I had lying around the shop) snaps right off.
I've taken it to 3 different machine shops and everyone that's looked says they've never seen anything like it. I hope that means they will look into it.
I don't want this to be a flame Wiseco or anyone else thread, just seeing if anyone else has had an issue and mchicia1 has.
Maybe something could be done, if not I guess my plans for the racing season are done lol.
Not to bash the original post because something went wrong and at least Wiseco is offering to look into it, but last time I checked, race parts are not covered under any warranty. There is no sure way to determine fault and I think it's a little pre-mature to blame Wiseco.
Built a new standard bore 6.0 with Wiseco pistons. Broke it in, changed the oil. Took it to the track, it started smoking on deceleration.
Got the motor out today after a leak down test showed there was a problem.
5 of the 8 cylinders had broken oil rings. Never seen that before. Compression rings were fine except for it collapsed the ring land on the second ring and the second ring is stuck on all of them.
The oil rings are if a bunch of pieces on each one. Pistons are garbage as well as the cylinder walls.
It sucks but this what happen and it was preventable. Live and learn
There are more variables besides being properly assembled. OP stated he broke the engine in and took it to the track. Did he do proper break in procedures? Did he overheat them? Inadequate lubrication etc..etc...
Nothing to do with break in here.
I will post info when I get block to machine shop.
FWIW this was a standard bore engine. Wasn't bored.
The skirt damage appears to be from the broken ring fragments. Cylinder walls have some nasty ridges.
If this engine was stock bored untouched. No final hone for 2618 pistons. That is machinist/builder error. Your 2618 pistons expanded with no room from clearance they binded up. And cause this damage.... you cannot put 2618 pistons in stock bored block and not expect have total damage. you have to finish hone the block for the correct pistons. (2618) pistons expanded alot.
The taper is tighter in the bottom of a stock block than in the top.
#32
Dude I'm the michael jordan of building these types of engines.. Any machinist will tell you that cylinder bores have taper. Even those 2618 pistons have a taper brand new that is intentionally there.
I feel bad for the guy. But a dial bore gauge is a must when dealing with 2618 pistons.
#37
You can't break piston rings unless the bore is out of round. And out of round is TAPER.
You're welcome.
#39
by the way I'm the Jimi Hendrix of building motors!
And look at the middle of the piston.......not even touched! Bottom and top are destroyed! Your diagnoses is so far wrong you are playing with dolls not basketball.
#40
Listen Helen Keller I am NOT going to keep going back and forth with you on this alright. Those pistons are expanded at the bottom first the wear is severe at the bottom of the skirt. As the piston expand more and more the rings binded in the bottom of the bore. PISTONS AND BORES ARE TAPERED NOT JUST PISTONS. This is why a dial bore gauge is a must. But anyone can tell you CYLINDER BORES ARE TAPERED AS WELL. Which is why you measure each piston and assign it to a bore after you have measured the bore with a dial indicator. Bores have TAPER and So do pistons Jimi Hendrix... now put down that booger sugar and concur with MJ.
Now let's wait for the results from the guy who has this problem. And we will see who's correct.
