What is a good cam for LS1 w/ported 5.3 heads ?
Looking for a good street/strip cam for a 99 Trans am stock LS1 shortblock with ported/polished 5.3 heads with 2.02/1.6 valves,not milled.Customer wants a rough idle,the engine in the car now is MS4 cam only,he likes that idle now its 111lsa.I dont think that cam will work with those heads ? I feel like he needs alot more lower rpm power as he hardly ever races the car.Other mods are LS6 intake,4000 stall.What cam will work good with the 5.3 heads without ptv clearance ? Thanks
I don't know...I have seen quite a few MS3 combos w/ the 5.3 heads
I'm sure someone who runs one will chime in, but I don't think its too big for what the intentions are.
The following users liked this post:
1SlowLemans (10-09-2021)
The PTV clearance is tighter with the bigger valves, but duration not lift will be the key factor!! Best bet is let the cam gurus answer that one! Give Martin@TickPerformance a call, their SNS Torque Max series might fit the bill!!
