Guess we are going to do H/C on the Z06... Need Advice.
Looking for maximum power from 4500-7000, street manners and emissions be damned.
First thought is:
Grand Cup cam
GM CNC 11:1 heads
Breathless Long Tubes
What are my other serious options for an M6 in the $3500-4000 price range that will make this bitch rock?
First thought is:
Grand Cup cam
GM CNC 11:1 heads
First thought is:
Grand Cup cam
GM CNC 11:1 heads
First thought is:
Grand Cup cam
GM CNC 11:1 heads
Drag race and AutoX, with the emphasis on Drags.
Too hard to use the car as a daily driver anymore, because of the kids, want to get low 11's NA.
McRat, as far as cylinder heads go I would give Richard at West Coast Cylinder Heads a call. He's right down the street from MMS in Reseda and he's gotten some great numbers out of LS1/LS6 heads and is a great guy. I think he got 340cfm out of a set of LS6 heads for Dave (Formulation/427 LS1). He's a sponsor here so you can find his info there--->. If you're only purpose is drag racing/auto x I'd go with a solid roller cam for max power. Futral Motorsports has made some awesome power with some solid roller's even with a stock LS6 intake. I'd go with 1 7/8 headers and a higher CR (maybe 12.1) if you're going with an aggressive heads/cam setup and don't care about emissions. Good Luck
Thanks Tony.
We are prob gonna get 1 7/8" tubes, looking right now.
I want to run the Z06 sodium valves and springs. After hearing so many horror stories about busted valvetrains, I think I'm going to trust GM's springs and valves.
All the heads I see when I look are more $$$, and the need cores. I'll check out West Coast.
The reason why I'm leaning towards GM stuff, is that it tends to be fool-proof.
I can't find anyone selling a solid cam. Who makes sells solid cams?
First thought is:
Grand Cup cam
GM CNC 11:1 heads
First thought is:
Grand Cup cam
GM CNC 11:1 heads
Thanks Tony.
Dave Farmer ran the GA cam for a couple seasons in the SCCA/World Challenge Series. He told me he ran stock lifters, stock rockers, stock valves and the GMPP heads ( by the Rules). Spun it to 7500 routinely and replaced parts as needed. He felt all the GM pieces were very durable. FWIW.
joel
joel
joel
