Stupid Question but I gotta ask TEA Trick Flow 215s
I have been asking around and cant get a solid answer so I will show my ingnorance. I have some TEA Trick Flow 215s for LS1 and need to know if they fit the 4.8, 5.3 and 6.0 blocks also? Thanks for the help.
Unless the bore was opened up to 4.00", they are best suited for a 3.9" bore.
You could run them on a 6.0 liter as long as you had gaskets to match the bore.
I don't know if the larger 2.04 valves of the TFS 215 heads will work with the smaller bore of the 5.3L.and 4.8L. I think it is too much valve for the bore.
