need some cam advise
ok so I see tons of people asking about cams and im sorry to be another one! but im doing a different build than most people here. im building an lq4 for an off road race truck. I was looking into getting some l92 heads plus a nice cam but I don't know what I should get. I want low end torque but it still needs to have power around 5500ish rpms. I have a th400 built for the motor plus a 9 inch rear end. im thinking of running 5.13 gears for 37 inch tires. and also I was curious of what intake to use too. should I use the truck manifold or like an ls6 intake? advise please!
With such a vastly different vehicle than most of the ls off the shelf cams are designed for I think your best bet would be to get a custom grind cam. I would give Martin at Tick Performance a call, he can set you up with a cam that will match your needs.
